To say what to look at, please define what kind of change you’re aiming to? Less brite or more everything?
That’s tone circuit in the NFB partion of an operational amplifier stage.
R12 ratio to two 3.3Ks parallel with pot between sets gain and pot setting also affects low freq content passing to gnd through C11 and C8 via C7. C7 reduces tone pot scratchiness. C5 passes high freq back to -input and reduces treble content.
Feel free to fix me if I got something wrong.
For getting it familiar, throw your remains to The Boneyard.
Part 2 deals with the topic of how opamps are used in pedal circuits.
There are four basic building blocks made from opamps and used in pedals. Buffer; Amplifier; Limiter; Filter.
We'll use examples from the Friedman BE-OD since it contains all four building block types.
Here's a unity gain buffer. We use negative feedback from the output (pin 7) to the inverting input (pin 6) to control the gain. Since we have 100% feedback, the gain is unity. We use a buffer when we need a building block with high input impedance, low output impedance, flat frequency response and 0dB gain. It...
