How to test a PCB with Protoboard Micro?
zipfool
I'm wondering if it's possible to use a Protoboard Micro to test a newly-assembled PCB. I would assume that I don't really need to mess with the stomp switch connections at the bottom of the board, but besides that, what connects to what?
  • Like
Reactions: fig
Yep - just attach the + to one of the VCC points. - to GND. Then attach the IN and OUT wires to the corresponding pads.
The pots will need to be soldered in place as well.
Thanks! What about the VCC and GND terminals on the left and right sides of the Protoboard? Should I hook the input/output GNDs to those?
  • Like
Reactions: fig
Those are optional. They align with the power rails of a breadboard. I use pogo pin clips with the protoboard and it makes it a breeze!
Here's a repost with what I use (2 4pin single row). They work with a lot of the PedalPCB boards.
