Hydra Delay Question
steviejr92
Authorized Vendor
So im going through the build docs for it and im running low on b100k pots i only have 2 and the build doc calls for 3. I have A100k pots to replace one of the pots with, my question is it ok to go with this taper and which knob would you replace?
One more i promise :D X1 asks for a DT-38 I have AB38T. My experience tells me the letters shouldnt mean anything but i dont know a thing about these crystals and have only installed them a handful of times. Just want to make sure replacing it with the Ab38t is ok. Thanks guys!
For anything with an FV-1 you’d be better off scaling down to B50K or even B10K than changing the taper on the pot inputs. Since it’s just acting as a voltage divider for a digital input, the value doesn’t really have an impact to anything but current draw
So changing the vol to a b50k wouldnt hurt it too much right? Its still going to be loud id imagine?
Volume is in the analog signal path so I would leave that as a 100k. Either Speed and Age could changed to B50K with absolutely no difference to the sound— both are just acting as voltage dividers to set digital parameters with a control voltage.
