giovanni
I find that confusing because the emitter should be at a higher voltage than the collector in a PNP, so to me E is at the top, C at the bottom.
This is the first thing I've done with a PNP, so I'm still getting to grips with the differences!I find that confusing because the emitter should be at a higher voltage than the collector in a PNP, so to me E is at the top, C at the bottom.
Hi @JTEXEasy. Put the whole thing in Tina-ti and see if it works. I have $20 that says it doesn't. But what if I'm cheating and I've already done that?
(I haven't)
It won’t unless it can simulate the leakage current of those two caps (a resistor in parallel should do that trick). That’s my bet.Ok, now I'll really put it into Tina if I find some time. As drawn, it really looks to me like it shouldn't work. Will let you know.
Then I’m out of theories! This circuit is very weird. Maybe somebody more knowledgeable can chime in.A capacitor couldn't leak enough current to turn on a transistor and still be considered a decent capacitor..![]()
