Each pedal will have its own 3dpt the method above is the way to go for 2 or more pedals in a box but the pedal pcb bf-2 has 6 header pin or wires if you like and they attach to the switching pcb on the 3dpt which has 6 slots so do I take the out from the phaser or chorus and solder it to pin A on the switch or pin B or lug 1 or two on the switch ,the main board and the pcb that is soldered to the 3dpt had no markings at all and there is no instruction pdf.I don''t want damage the switch pcb and end up with popping issues do it once do it right. E and F would be for output or lug 7-8Cool project!
I imagine you want separate stompers for each effect, but …
If all the pedals are always on, I’d stick the circuits in the order you want them and wire the in-jack to the 3PDT and from there to the “in” of the first circuit, “out” of the first directly to “in” of the next, etc — then the last circuit’s out would go to the 3PDT and from there to the out jack.
Are you using a single 3PDT and will it have a daughter-board? Or will you use a relay-switch?
If you need each circuit-effect to have its own bypass, then it’s slightly more complex. There are online tutorials on how to wire 3PDTs as well as dual-effects pedals — I’d start with those, and then the MFX is just like a dual-pedal repeated a few times.
PedalPCB Wiki
wiki.pedalpcb.com
There’s more online, but PPCB’s own Wiki/FAQ should get you on the right track.
I have done many 2 in1 enclosure pedals but this wont work ,I wired the chorus out to flanger lug 2and there was as Jimilee said heterodying but not working as far as strumming goes ,then soldered to lug 1 again no go, this is what I feared would be the case ,someone talked about this being Boss flip flop wiring what ever that is ,the out from the chorus needs to be soldered to some point on the Byz but where ,where is Admin. for some help, Even when the chorus is off there is heterodying, from the flanger ,soldered to lug 6 then lug 3 because there is various continuity from pin 1-2 and lug 1&2 and 3&6I’d test/trace for continuity of what goes where with the 3PDT daughter-board to the main board; my understanding of the Byzantium PCB-set is the in/out from what would normally be the jacks is direct to the main board (marked “in” / “out”).
Wire up the Byz’ daughterboard to the main board as you normally would if it were a standalone build — simply match the 6 holes left to right between the daughter and main PCB.
The out of the chorus or phaser goes into the Byz’ main board “in”, and Byz “out” goes to whatever is next in the chain.
The “in” “out” on the main board is routed to the Byz’ bypass, you can check to make sure with a DMM.
You don’t need to wire anything from other FX directly to the Byz’ 3PDT.
To clarify 3PDT pin nomenclature, the pins are numbered thusly:
1 4 7
2 5 8
3 6 9
Pins 123 form a pole, sometimes referred to as pole A, 456 another pole (B) and of course pins 789 form the third pole (C).
Yes, normally the in-jack wired to the main board “in”, but the main board is just shunting that input signal to the 3PDT which in turn bounces the signal back to the actual flanger circuit (or to the bypass “out” of the main board). That’s my understanding.my understanding of the Byzantium PCB-set is the in/out from what would normally be the jacks is direct to the main board (marked “in” / “out”). I soldered the out from the chorus to the wire on the input jack coming from the Main board all I got was rrrrrrrrr
so far soldering from chorus out to lug 1 or 2 has failed ,the trace from the input jack on the main board of the BYZ has continuity with lug 2 but that failed using DMMYes, normally the in-jack wired to the main board “in”, but the main board is just shunting that input signal to the 3PDT which in turn bounces the signal back to the actual flanger circuit (or to the bypass “out” of the main board). That’s my understanding.
To reiterate, pics of your wiring or a hand-drawn diagram of what you’ve got would help.
Fixed : the problem was combining ground from one pedal to the other ,both pedals had their own power supply but you need to run a ground wire together ,running the out from the chorus to the main board as above works but you need to connect ground together, normally you go from 3dpt to 3dpt ,testing the flanger I connected in and out jacks last week ,this will be handy with another boss pedal the last in the chain the aqua boy delay ,Thanks for your help Feral Feline,The over drive is a bohgner la grange clone going for EVH toneChorus out shouldn’t go to the Byz 3PDT, it should go to the Byz main board marked “in”
You did help by insisting I connect to to the Main board ''in'' as this is the ''in'' normally coming from the 3dpt, I did connect to the Main board before your suggestion but without connecting the grounds it didn''t work ,till I connected the grounds that is ,I''m not set up to do a video but it sounds great very low noise ,if you turn the clock trimmer past 40khz it gets darker but volume drops so I leave it at 40khz ,once again Thank you.!!!I don’t think I helped at all, YOU figured out the ground issue all on your oddy-knocky whereas I forgot all about grounds.
Congrats on Doing It Yourself!
Looking forward to hearing clips …
