Impedance issues with filter project.
Morbidpale
I have been working on a dual filter pedal. Something very out of my wheelhouse. I liked one channel of the DBA Sound Saw so I started learning about notch filters to create a second channel I liked. The circuit needed some more volume and I wanted to stay with the reverse beta theme the circuit already had at the end. BUT i have terrible input impedance (I learned how to test that, this has yielded lots of new information). I want to place this after my dirt pedals so...
How can I fix my impedance issue?
Are the reverse beta stages the problem?
Can I work around that?
Am I in Jack Orman Pickup Sim. territory now?
I’m just throwing some ideas lifted from recent reads with pedal stuff and deeds with tube amps. Nothing technical, but hopefully practical with some adjusting?
  • Tone stacks can be considered as lossy for gain. For this reason a cathode follower stage is usually used before tone stack in tube amps to make gain loss smaller. Regular and boring emitter follower stage before tonez controlz?
  • Try darlington transistors for q1&4. Higher input impedance and more gain out.
  • Jfet input like in DBA Germ filther found in Boneyard page two. More invasive solution for sure.
  • Buffer stage before q1? But I already said it first! Buffer dat.
