Infanem 141G and Driving Notion
gila_crisis
Fresh from the workbench a pair of Infanem clones: blue Driving Notion and bare aluminium 141G.
141G: this was a straight forward build. I went for the G version (somebody who owns both G & T versions reported me that: "G has the most mids for sure. It's not properly a mid boost, but it's way more mid voiced than the T, which is mid scoopedy", so G it has to be).
I did a tweak and installed 4.7uF NP caps instead of the 10uF NP, as I felt the sound was a tiny bit too bass heavy (but in a good way), and played a bit around with the transistors to get a different texture than with the stock 2N2222 (for example I used some MPSA18 and BC239C instead).
Driving Notion: this gave me a long afternoon of multiple headaches, as the "good folks" at Banzai Music made a tiny delivery mistake (and it's not the first time such mistakes happen with them...). They sent 4k7 resistors instead of 47k, which totally un-biased the circuit... anyhow (and yes also my fault I didn't double check the parts prior soldering), after I found out the mismatch, and recovered some 47k resistor from my house stock, the pedal started working properly!
Here as well I did some tweaks, especially in the High part of the circuit: I used sockets for R30 (which is actually an extra capacitor) and after few trials I ended with an additional 2n2 cap in this slot, as it adds a nice extra grit to the distortion (but I wouldn't go higher that 4n7, otherwise the up position on the thicker switch sound a bit useless). Further, I socketed C12, as I found a pair of schematics with different values for this part. The stock per Deadend schematic 1nF sounds a bit too glassy/piercing IMHO, so I tried bigger values. I ended with a 47nF (still bright but fuller and without glassy-ness, but already 10nF sounds way better than then 1nF).
Finally, to properly bias Q6 and Q7 I installed 100k trim pots for R23 and R26, and doubled the values of C19 and C20 to have even more range from the Thicker switch.
I really like these 2 overdrive/fuzzes, they have a strong character of their own, and the circuits are very different from the usual stuff I see around. Highly recommended for everybody who's looking for something unusual but cool.
As usual: big kudos to Deadend FX for the stellar PCBs and their efforts to preserve knowledge about these lost gems!
I seem to remember your username from the old Fennec Electronics forum
I was mostly a lurker but it lured me into DIY pedals, I still have a couple of saved projects from there
Great builds!
I built 141G recently and really liked it too.
How much auditioning of parts did you have to do with the Driving Notion?
I'd love to see DEFX trace Infanem's Faye Sing A.. it's my white whale circuit.
Great builds!
Thank you!
I was expecting worst: I had some BC550C and MPSA18 to chose from, and to my surprise all were very fine and in a "bias-able" range.
Where I had a bit problems was the J201: I have few in stock, but had to jumper the 68k resistor in order to be able to bias.
I love these, especially the 141G: super cool sounding fuzz, really these nail that broken/rough sound I always had in my mind.
