Installing a Copper Clad fuzz in a guitar with a PedalPCB board
^ I think it is too. My guitar had a pop when I turned on the switch when it was wired like this. You could try wiring it with the switch on the ground side, and such that the input of the PCB is grounded when it's off. I'm wondering if you would also need coupling caps as well
the idea being that grounding the input when the effect is off will allow the caps to discharge into ground. But I'm not sure how the PCB will like having its ground lifted. A 4pdt switch would allow for power application as well as grounding when off. But try it this way and see how it works
Try this View attachment 98157
I followed this diagram and it's working with minimal pop! Thanks so much!
So I have a 1n cap, where exactly would I be putting it? From the signal input on the effect board to ground?
What is likely happening is the electrolytic caps in C3 and possibly C1 are leaking DC voltage to ground and causing the pop. Elec caps leak more than others. This means they let DC thru when they shouldn't. If you want to experiment a little, find a 2.5uf film, MLCC, or tantalum cap and install that instead of C3. If you use a tant, just make sure to get the polarity right.
Yes, first component in the circuit and going to ground. It just takes some high end off, including radio and hiss, if you have them. It won't solve your popping issue, however.
