Greetings all. I'm a newly minted retiree that grew up and lived in NH until I retired last October after which I moved to southern Missouri. I have either worked full time or part time, depending on pressure from my wife to make more money, in the audio repair business. I've worked for many years as a tech in one of the the premier music store chains in New England until I saw the writing on the wall and moved on, after which they closed about 9 months later (but not because I left...LOL). I still repair stuff for local musicians and hope to go full time, more or less, once I can suss out the business tax laws here in Missouri.
Anyway, I am also a bass player and had a DemonFX Call76 given to me that didn't work which I fixed. The question I have about this pedal is this. It's very obviously a clone of the Origin Effects Cali76 with a few curious changes.
Those of you that are familiar with the OE pedal knows that there is a bi (tri?) colored LED on the top that lets you know what the compressor is doing. This is not on the D-FX pedal...but there is a dual row of 5 blue LEDs inside the box (a lot of good those do!) that seems to do what the jewel-lamp gain reduction metering does on the OE box. Does anyone have a schematic of either of these pedals that I can see what they're doing and how OE achieves the gain reduction metering with the LEDs under the jewel? I would like to replicate what they do.
The other alternative is to mount a 5 segment LED bar graph to the top of the pedal and wire each segment to each individual LED buried inside the D-FX pedal. I would probably need to remove the five LEDs on the PCB inside the pedal to do this.
I can post pictures of these LED's and where they are in the D-FX pedal if you need me to.
If you get a chance, let me know your thoughts on this.
Thanks,
Tim
Thanks,
Tim
