I completed a Kliche build and it does not seem to be passing signal through. I have tested it and the LED comes on with the footswitch as normal. When off it is silent but does not pass guitar signal through. When on there is a slight noise floor (very mild and acceptable) that increases slightly as I turn up the knobs, but still does not pass any discernable signal.
I have made some small substitutions.
D1 and D2 are now a BAT41 and a BAT46 respectively. I understand this will result in asymetric clipping with a higher threshold, which is fine.
R11 was supposed to be a 422K. I used a 392K because it was the closest thing I had on hand. I do not believe that will affect function.
I used a ribbon cable with the footswitch breakout board. I have checked to make sure the soldering is clean and small. I don't think (?) anything is grounding accidentally. It does the same thing with both a 9v and an isolated power supply. Thanks for your consideration!
