Spark_Trooper84
Hey all,
I'll soon be building out the Abyss project, and as you may know finding KE-10720 LDRs is pretty much a no go anymore.
The specs of a KE-10720 LDR are Photo Resistance at 10LUX: 10KΩ-20KΩ, Dark Resistance Min: 0.5MΩ, and maybe rise/fall time at 35 and 5ms respectively.
I've seen elsewhere that the GL5516 has been suggested, and indeed PedalPCB carries them
Those specs are Light Resistance: 5 – 10KΩ, Dark Resistance: 500KΩ, and rise/fall time of 30 and 30ms respectively
The GL5528 is closer, at Light Resistance: 10 – 20KΩ, Dark Resistance: 1M, and rise/fall time of 30 and 30ms respectively
However, I was searching around on Mouser and found these that are probably a MUCH closer match to the original KE-10720
This unit's specs are Light Resistance: 9 – 20KΩ, Dark Resistance: 500KΩ, and rise/fall time of 60 and 25ms respectively.
So, my assumption is that the ones I found on mouser would be the best (almost) direct replacement LDR simply due to the specs.
I've order a few of them to try out in the board when I build it, but i've also ordered some GL5516 and GL5528 LDRs as well just in case.
What is the collective thoughts on the Mouser units I found, if if they would be a more suitable replacement (perhaps even close enough to just say that the build docs could be updated for this more easily sourced part?
