Hi everyone,
This is the first time that I'm building a pedal on something other than vero, and after looking at the build guide for the Leprechaun PCB I had some questions.
- I can't find a picture on how to do the off-board wiring for the LEDs, should I just follow existing guides on how to wire (for example) 3PDT true bypass?
- a large number of the capacitors are labeled as MLCC; those are just ceramics, right?
- the PCB suggests that I need to add electrolytic caps in a number of places, but the parts list only specifies one. Can/should I still use electrolytic caps in those spaces without breaking anything? (C3, C6, C17, C22, C31 and C36 respectively).
Thank you kindly!
Thank you kindly!
