EisengesisFX
I know, there's other threads! And I done checked 'em! And I'm enough of a noob to have questions remaining! I'm building a Leprechaun and trying to install an Intelligent Relay Bypass module on the Regen/Magic switch.
1) This is the style of switched TRS jack I got. I'm looking at the diagram on the LMS page I ordered it from and I have no idea how to discern which tip is the switched one. Which is it?
2) I ordered the Intelligent Relay Bypass Module and ordered some of these normally-open momentary SPST jawns. Is that a mismatch? Did I fuck up?
3) If said module and switches are in fact compatible, which of the footswitch solder pads on the module PCB go to which of the two lugs on the switch?
Thanks in advance as always!
