Stickman393
A'ite,
I'm going to use an example of a pedal that I recently built. I've attached a simplified version of the circuit: this is the "wah" section of the Cosmo King Wah/Ringmod from DEFX:
This was done with the assumption that the wah pot was at it's midpoint. I then modeled the input impedance by plotting V(input)/I(V2):
Assuming that I did all that right, this confirms something that I had suspected: that this design has a quite low input impedance.
If I'm thinking about this correctly: if an effect's input impedance is too low, that reduces the overall peak to peak voltage that a pickup is able to produce because the effect circuit is, for lack of a better phrase, "Current Hungry". Therefore a low input impedance will load down the guitar pickups: any increase in peak to peak voltage will increase current as well. Because the guitar's pickups are limited in how much current they can produce, a low input impedance will sacrifice some voltage for current.
By using a higher input impedance, an increase in signal voltage will result in a smaller increase in signal current. This allows for a wider dynamic range. Did I get that right?
So...what are one's options if one wants to "correct" this in an existing design? I'm familiar with seeing 2.2M resistors tied to ground immediately after an input: doing so in LTspice certainly does the trick. I realize I'm creating a voltage divider at this point if I do so, which will attenuate the signal to some extent. Though how much I can't say: 27K is, what, 1.2% of 2.2M? Realistically speaking, the majority of the current should still be traveling through the 27K resistor.
Are there any considerations there that I'm not seeing?
I suppose another option here would be to add a buffer to the input stage, though that would be more involved.
Any insight y'all could provide would be greatly appreciated. Stickman bang rocks to get er, learn good.
