GAStan
Is Q1 base biased too high? It looks like Q1 is fully conducting (on). This would indicate too high of voltage on the base. this will give very asymmetrical clipping. What kind of clipping is desired? For symmetrical shouldn't the collector be at ~4.5 - 5 volts?
But the pedal sounds good with the current Q1 and Q2 setup.
As far as checking voltages I see the biggest change in Q4 (2N2222A), the next biggest at Q3 (MPSA18).
@Ginsly what do you have available for test equipment?
