PangeaDestructor
I finished up the Low Tide this afternoon, super excited about this one but I’m having some issues. Switches on and off just fine, but I get a big volume drop when it’s engaged – it’s barely audible with the vol knob maxed - and none of the controls seem to do much of anything except for an occasional minor warble sound and some static white noise with the mix cranked (got a radio signal for a minute as well). Same with both trimpots, neither does much of anything and there’s no hint of the BBD kicking in. Tried the dip switch, same thing. I snagged the v3207 from cabintech a month or two ago, and it says Cool Audio on it so I assume it’s legit. My LM13700s are from Amazon but I’ve had no issues in other builds and swapped several chips here with no change.
I used a linear dual pot for the slew knob and 2SK30A in place of the 208-Y but otherwise everything is as per the BOM. Made a mistake with the drilling, obviously, and haven’t soldered the LED yet because I’m waiting for a bezel.
IC2
(1) 4.62 (2) 4.94 (3) 4.92 (4) 0
(5) 4.94 (6) 4.92 (7) 2.10 (8) 2.10
IC3
(1) 1.20 (2) 4.94 (3) 4.36 (4) 4.36 (5) 5.46 (6) 0 (7) 5.46 (8) 4.35
(9) 1.20 (10) 4.95 (11) 4.36 (12) 4.36 (13) 5.57 (14) 8.22 (15) 5.58 (16) 4.36
IC4
(1) 1.35 (2) 2.46 (3) 2.44 (4) 0
(5) 8.2 (6) 1.83 (7) 1.83 (8) 1.83
IC5
(1-3) vary from about 1.89 to 2.14 (4)- 0
5- 4.94 (6) all over the place (7) 2.09 (8) 2.10
IC6
(1) 0 (2) 2.33 (3) 2.37 (4) 2.37 (5) 0 (6) .61 (7) 59 (8) 0
(9) 4.95 (10) 1.10 (11) 4.94 (12) 0 (13) 3.16 (14) .34 (15) .68 (16) 1.77
IC7
(1) 0 (2) 2.37 (3) 1.84 (4) 4.61
(5) 2.02 (6) 1.91 (7) 2.33 (8) 4.94
IC2
IC3
IC4
IC5
IC6
IC7
