So I built a Low tide mini and a Chop shop... neither worked first time... but it's my first time using SMD components so it must be that right?
The chop shop it turned out to be the 2N2222 that needed replacing and it works...
The low tide mini is a bit more daunting to look at...
So first things, before I waste anyone's time with pictures... is there a order you would test things?
Going by the schematic here https://docs.pedalpcb.com/project/LowTide-Schematic-PedalPCB.pdf with an audio probe I've got Signal coming out of Q2 fine and Q1 and Q2 seem to be doing what they should .... I would have thought I could got the mix control to dry and get signal to the mix and level pots but it doesn't look like it :S
