SOLVED Madbean total recall
Phil hodson
Morning all.
It pains me to post this here as I took my time on this one as I knew it’s a complex built. I was hoping to beat @MichaelW to a build report but we both hit problems at the same time. He got a new board and got it working. I’m persevering with mine thought as I want to know what I have done or not done!
So before I loose my patience and or my mind and start ripping things off the board I thought I would ask around on here. I know there are some very accomplished builders and some total recall experts here!
Firstly I have checked values. Cleaned the board. And started an audio probe.
Going from the main audio schematic it’s all good. I get a squeal on pin 3 of IC3 not sure if that’s an issue.
Audio stopped at C14 so I replaced that and it’s fine now. All the way to D in. After that nothing.
I her audio on pin 3 and 4 of IC6 but no delay at all.
Looking at my voltages everything looks good apart from IC4. I get nothing at all ok the right hand side.
I also get no voltage at pin 7 of IC7. Could this be related to the issue at IC4?
My thoughts is a bridge or issue in the socket for IC4. Before I take it off does this sound like it might be the issue?
Any thoughts and suggestions very very very welcome!
See attached pics. Can take more as required.
Phil
Was so happy to see that icon:
Knew you'd get to the end eventually...
Congrats Phil and everyone else who contributed — as JamieJ said, way to persevere!
