Marsh Fuzz
HamishR
Wow. This thing is amazing - and it probably should be because it used up a heck of a lot of 22uF caps!
Seriously though I am really impressed. With a Strat this thing is crazy. Clean boost all the way to Fuzz Face style fuzz and a very cool overdrive in between. This is probably the fuzz-meets-overdrive pedal I have been looking for. There are a LOT of sounds in here. It can be a chunky OD with my Gibson, a Jimi-fuzz with my Strat, Gilmour FF to Muff sounds with the Strat - you could almost get to Satisfaction!
The board is again super easy to use and makes for a clean build. The only change I would make would be to find the proper C taper 1K fuzz pot - I didn't have one so used a B1K pot. So that's not the pedal's fault, it's all mine.
The EQ is well-sorted so it makes getting quite different tones easy. Full, taut FF sounds as well as clogged Muff sounds are here. Getting fat cholesterol with definition is easy because of the separate treble and bass knobs. I might just have to make another one. Love it!
