Hi all,
Just building a duo phase and I have LDRs with the specs - 10-20k and 0.5M and 540nm.
Firstly will these do, they are same specs as the ke 10720 that people seem to have used?
Also the main question is that the build docs say to use a yellow led which has a wavelength of 575-595nm whereas a green led is 500-570nm. Should I be using a green led? Also I only have the waterclear LEDs does this also matter? Should it be diffused?
Am I thinking about this too much? Should I just used the diffused yellow ones I bought.
This pedal will be a gift for a friend so I want it to be good.
Cheers.
Cheers.
