Meatball Madness!
Feral Feline
Let's talk about that Lovetone circuit so many adore, and some revile —
Whether you have an OG Lovetone Meatball, McMeat, Meaty Balls, MeatSphere, Rissole, Spectron, an other flesh&muscle orb, or just love the circuit...
For all you Meatball afficionados — who's using the expression jacks?
Which expression-jack do you use more, the INTENSITY or the DECAY?
Regardless of which you use more, which expression jack do you think is more useful to have (if only one)?
IF you were to give up one of the expression jacks, which one?
I've got the Aion Spectron board, I was thinking of having one expression jack and a toggle to switch between INTENSITY and DECAY.
That would free up a topjack-space for moving the EXTERNAL TRIGGER jack from the side up to the top.
After years of random research I've come across people who've added
an "external" LFO;​
longer decay mod;​
light-jack (LDR expression);​
FX-loop buffer;​
buffered bypass so whatever is in the FX loop can be used even with the Meatball's filter "OFF";​
phase inversion for LP and HP modes so the BLEND works no matter what;​
modded COLOUR range;​
compensated frequency response to better balance UP/DOWN modes;​
independent outs for dry and the three filter options;​
Moog mod, of course;​
boost...​
and...​
What else y'all got?
Oh, and about those expression jacks... Anyone?!
Let it rain...
I'm ashamed to admit, I've actually never used the expression jacks on mine. That's more to do with a lack of an expression pedal though!
At the risk of derailing this thread, do you have any recommendations? :)
From what I've read:
MISSION ENGINEERING, pricey but you get what you pay for.
Moog — available used only, I think, now.
Ernie Ball with the Zeppelin Labs mod
DIY convert-a-Crybaby
Boss are pretty good, whether the cheaper plastic ones (EV-5) or the metal FV-500H and EV-30... I'd get the EV-30, 'cause it's a little more compact.
From Experience:
NOT Yamaha. Don't ask.
Sorry, I'm late to this thread; also I feel a bit of a fraud because I haven't built a Meatball clone - I just own the Behringer version (please don't hurt me!). However, I do have some thoughts on the questions raised here, so I thought I'd chip in.
So, judging purely on the Behringer version, the Meatball makes great sounds, but there are definitely things about the way it operates that are very quirky (to put it kindly) and which I would try to address if I was building one.
  1. The sensitivity (at least on mine) is a bit low, even when set to max. I know the Aion FX version adds an internal preset to tweak this.
  2. The dry/wet blend control acts quite oddly as the dry and wet signals are out of phase. This was touted as a 'feature' in the original Meatball manual, but it's a bit peculiar! MarcoMike addressed this by adding an inverting buffer into the wet signal path, as described in this forum post.
  3. The effect return socket has some behaviour that may be found to be useful, or unexpected and annoying, depending on your needs. This is described (along with a mod to fix it) in the build document for the Aion FX version.
  4. Re the expression pedal inputs: the question was asked: which of the two is more useful if you were only going to include one - the answer to this is undoubtedly Pedal2 ('Intensity') - ie the filter frequency. I'm not sure if I would ever want to control the decay setting with an expression pedal.
    Having said that, the way the Pedal2 socket works is not ideal. It simply connects in parallel across the Intensity control, which is a 1KB pot wired as a variable resistor. So any value of expression pedal pot is always going to lose you a bit of filter sweep range at the low frequency end. Also any expression pedal with fripperies such as a minimum-limit knob (like my Boss EV30) will behave weirdly. (For what it's worth, I found that a C20K pot gave the widest and smoothest response - good luck finding that expression pedal!)
    In the same thread I linked above, MarcoMike describes a mod he did to add a more satisfactory expression pedal socket.
Hope some of this may be mildly useful rather than just a pointless ramble!
