Metal name plates for enclosures
Does anyone know where people are getting metal name plates for the top of their enclosures like the one on the Protein pedal by Browne Amplification or the Broadcast pedal
What do you think they use then double sided tape to attach to the enclosure?
Generally, with the pedals I own that use faceplates like that, they’re all just attached the the enclosure via the footswitch and potentiometer mounting, a few that only have a single footswitch and a single knob have a little bit of double stick tape just to keep it extra secure, but they all are otherwise just held in place by the pots and footswitches
Reactions: fig
Do they also drill holes for you or do you do that part yourself? When I drill the enclosures by hand (I don’t have a drill press) the positioning is always slightly off from the template...
Yeah you have to drill it yourself unfortunately. Pots tend to be okay because the knob coverage give you a bit of extra space to get away with. I have found the switches tend to be more difficult to drill for. It’s a case of measuring three times before you drill to make sure. I drill the enclosure then put the plate over the top then drill from the already drilled holes on the inside.
Another option is to attach the plate with a bolt and nut, ala Union Tube & Transistor.
Doing so also gives you the option for some creative knob placement as you can offboard wire everything and still secure the PCB with standoffs mounted to the plate's bolts.
Makes for a very robust build.
That looks really promising! Does anybody know if there something like that in the US?
They might post internationally. They are a Europe wide company.
I checked out the Marktek site it was so cool I tried to make a plastic faceplate. But I dunno if they ship to USA, it showed European countries and China as choices in the shipping checkout. Looked really useful and a good price too!
It shows on their FAQ page they ship worldwide
