balazs.bencs
I've started a quick new project because a friend of mine wanted a quick MIDI pedal that he can program up, so I did something really quick what worked for him but I wanted to start to build up something that can do a lot more. I remembered the MC4 Pro pedal from Morningstar, and I figured that I could do something like that with a cheap Raspberry Pi Pico 2 microcontroller.
Those things are dirty cheap, widely available and perfect for this application: one bigger screen, 4 footswitches, MIDI out, MIDI over USB, optional relay for amp switching, that sort of stuff..
I wanted to build a web app which you can use to program it up like the MC4 Pro, but with like an easier to use UI.
Here is the source code: https://github.com/balazsbencs/midi-pedal/
You can load up the https://balazsbencs.github.io/midi-pedal/ web app which brings up the programming interface hosted on Github - no installs are needed, just plug in the pico with the firmware on it and you can program up your MIDI commands.
This is an early alpha test release, but expect updates on this soon.
