Hi all,
I just built a Minnow (Maestro FSH-1) and am getting really pronounced ticking from the LFO in Sample/Hold mode whether bypassed or not.
I've read around about how other people have addressed the issue in this pedal and others with LFOs, so I have routed the output wire that would otherwise pass directly under IC2 (which I think is the source of the noise as I understand) under the board on the oppose side of the enclosure. I have tried a few different variations on the wire routing, but there didn't seem to be any change.
I could only source a B2M pot with solder lugs, so I had to connect the resonance pot with some short wires from the lugs to the board. I originally had those coming around to the top side of the board, and I tried shortening them and keeping them on the bottom side of the board. No impact there- same noise either way.
Here is the noise:
Any suggestions? Should I tried shielded wire between the 3PDT board and the jacks? I've read other people say that wire routing should address this problem, but I can't seem to get rid of it that way.
For people who use shielded wire- what kind do you use? Where do you get it?
Here is the noise:
