Mod Electronics Quasar Flanger
Synchrony Pedalworks
If you are a fan of flangers, then you need to build this flanger. This flanger is unique in that it does not use a typical MN3207 or MN3007 BBD. Instead, the BBD is a SSI2100 chip that has an integrated clock (and is cheaper). It sounds clean and amazing. I felt it was more like an Electric Mistress, but you can be the judge.
My only critique is that the board’s layout is hard to read, even with magnification. The off board wiring is also different, which isn’t bad, but just different. Regardless, give it a try.
