Moonshot Cap Voltage
According to the Tayda order:
10uF 50V 105C Radial Electrolytic Capacitor 5x11mm
SKU: A-4554
100uF 25V 105C Radial Electrolytic Capacitor 6.3x11mm
SKU: A-4541
47uF 100V 105C Radial Electrolytic Capacitor 10x12.5mm
"See if they fit" is a level of troubleshooting I probably should've checked first.
you'll have trouble fitting the 47uf caps in, but you can just leave the leads long and bend them over the board or mount them from the bottom in the same fashion, the others should be fine
Thanks. Was thinking of bending them if needed, but wasn't sure if the voltage would be an issue.
From an electronics perspective, what is the difference between, say, a 47u 100v vs a 47u 16v? I know this is basic stuff, just trying to wrap my head around some of it.
most of what we use are 25v and under. Boards that use a charge pump to put out 18v will require 25v caps at minimum (which will be in the build docs)
A quick word to the wise on those clampy PCB holders you have pictured, be careful because the teeth can bite and scrape through the masking exposing the copper pours beneath. Generally not an issue but it can open the door to some problems. Mine have some rubber nubs that I use to avoid this.
you can fold up some paper towel in there too for the time being
