Chuck D. Bones
Circuit Wizard
Another pedal from my brother's garage. I vaguely recall my roomie Richard owning this back in the mid 70's. I modded it for him by adding a DEPTH knob. He later sold it to me, I loaned it to my brother and forgot about it. Until a couple of weeks ago when he brought it back. Back in the day, nobody had a pedal board because there weren't that many pedals to be had. Big pedals were a thing. This baby is a boat anchor.
When I powered it up, no sound. I checked the LFO and it wasn't running either. Turns out that IC1 (the one on the right) had died. Not sure why, maybe someone hooked up the wrong voltage to it. There is no reverse voltage protection on this board. I pulled the LM2902 (same as an LM324). installed a socket and plugged in a new one. Voila! It works. As you can see from the schematic, it's a 6-stage JFET phase shifter. There's a 2-transistor buffer up front. 1/2 of IC1 and all of IC2 make up the 6 phase-shift stages. The remaining half of IC1 forms the familiar triangle wave LFO. It runs on a pair of 9V batteries. Not true bypass. The stomp switch simply disables the phase shifter by turning all of the JFETs fully on. The sketch at the top of the schematic shows how to implement more-or-less true bypass. The A25K DEPTH pot replaces R53.
