RobotZombie23
I have a Mosvalve 500 Amp for I use for Bass Guitar. It was hooked up to 2x12in speakers. Each 8 ohms. I think I didn't have it wired correctly. I'm moving all my equipment into another room and want to hook it up right this time. I want to make a back panel for the speaker box and was thinking of what connectors to use. I was thinking of using Banana Connectors on the cabinet but now I'm thinking 1/4in jacks. I think I want to hook up the speakers in parallel? and only use channel A on the amp.
The manual says: Min. 4 ohm per channel: One 4 Ohm system; Two 8 Ohm systems (in parallel); Four 16 ohm systems (in parallel).
and it says 8 ohm loads allow the most musical operation of Mosvalve technology
running them in parallel would be 4ohm load so I wont get "the most musical operation"?
I had it wired straight from the banana plugs directly to each speaker.
How do I properly hook this gear up?
