MXR bass octave deluxe randomness
LukeFRC
I picked up a secondhand broken pedal kit off someone, and he chucked in a faulty mxr bass overdrive deluxe for free.
Basically the thing doesn’t seem to be filtering the signal going into the detector- so there’s a constant noise coming out when the bass is plugged in but muted. Roll off the volume on the bass and it goes - so lack of LPF on the signal?
What would cause that?
- trace here https://www.freestompboxes.org/viewtopic.php?t=30057#top
So it seems that the it's high end content coming from the bass, that's inaudible until an octaver brings it down into the audible range...
looking at the circuit ... green is a buffer of some kind? - which then goes into the two octave circuits and the envelope follower/frequency divider bit.
The odd thing is if I touch the circuit with an Allen key (so ground it via me?) at either of the yellow spots the noise goes. Caps don't show as open.
