drew.spriggs
Standard models do 200v @ 45mA out, HV does 250v @ ~38mA, HV low noise 250v @ 30mA from a 12v supply. No heatsink required if there's ambient airflow. Apparently they are what the new Stewmac amps are using for a HV supply. $16USD.
Enable pin can be switched by just about anything, allowing for an easy way to delay HV after heaters warm up.
Horizontal module is about 25mm^2, vertical module is 16x8mm. All will fit onto standard header pins.
Looks to be a ridiculously easy way to generate HV for small amps/preamps!
https://www.shop-tes.com/power-supply/
