JTEX
I tested an OPA2310 the other day to see if it makes sense as a headphone amp, given its high output current capability (150mA) and very low idle current (~165uA per channel). Great for battery power! Only problem is that it doesn't take more than a 6V supply. But a low quiescent voltage regulator can take care of the that.
It's funny, I contacted TI to ask how they feel about this use case, since the datasheet doesn't give any performance data for such heavy loads (most common headphones and earbuds are between 16 and around 50 ohms or so). After many back-and-forths, they admitted they never officially tested it with loads below 600 ohms or so, so I was basically on my own.
I'm pleased to report that it does a great job. I got 150mW out of it into 16 ohms, and 110mW into 32, at less than 0.5% THD. That is really, really loud! More so than many dedicated headphone amp chips, while consuming quite a bit less idle power.
Caveats: to get the lowest THD (below 0.5%, typically <0.1%) you must use it in a non-inverting configuration (inverting doubles THD), and at unity gain. Any additional gain increases THD, so you're better off adding a separate gain stage before a unity-gain OPA2310.
Which brings me to the second opamp I discovered: OPA313. Would make a suitable gain stage before OPAx310. Also a low voltage part (<6V), but it only draws 50 microamps while having a 1MHz bandwidth and significantly less noise than a TL062 that draws 4x as much juice.
/endbraindump
/endbraindump
