talljohnbrown
I recently finished a Mofeta build, and everything seems to be in good order with the exception that I am getting no sound from the "Normal" channel. The bright channel is working great, and I know that there isn't a bias issue, as I was able to get the gain and bright trim pots set up in a way I like. When I went to go adjust the normal trim pot I wasn't getting anything. I should mention that the normal knob was turned all the way up and the bright knob was turned all the way down and the level was also turned all the way up. I have verified I am not having any shorts, which leaves the possibility of a bad component. The tricky part is I am not sure what it would be. I have tested both the 100p, 22n, and 47u cap and all seem to be in working order. I might end up replacing them anyway, but I am about 50/50 on desoldering components without ripping the copper pad off so that is a last resort if I can keep it to a limited number of components to replace. Any advice as to what other steps I should be taking to figure out why this is happening?
