ramonolague
Hello,
I’m running into noise issues while prototyping two circuits on the same breadboard. I’m trying to combine a Ritual Fuzz (Colorsound One Knob Fuzz) and an Acapulco Gold into one enclosure, with some mods to both circuits plus an input gain pot.
The issue is that I can’t power both circuits at the same time without introducing noise and squealing. If I power only the Ritual Fuzz, it works perfectly. But the moment I power the Acapulco Gold circuit — even without routing audio through it — the fuzz starts producing artifacts: a faint background squeal, ring-mod-like sounds as notes decay, and a quiet high-pitched hum when the guitar volume is rolled down to zero. As soon as I disconnect power from the second circuit, everything goes back to normal.
I suspect it’s a power-related issue, but I haven’t been able to solve it. I’ve tried adding caps to ground and splitting the power rails, but either I’m wiring something incorrectly or overlooking something obvious. Any help would be greatly appreciated.
