Number of 9mm pots for a 125B enclosure
JamieJ
I have a build in mind that I want to put together a PCB for. I want to use a 125B in a vertical position. I am working today and haven’t got my laptop to check if the spacing would fit. Would it be possible to fit 4 9mm pots in a row with the smallest knobs I can find?
If not I’ll have to use a 1590BB in a vertical position.
Well, if you can fit 3 16mm ones in a row it should be possible to fit 4 9mm ones since the total space is 48mm vs 36mm? You’d need to look at the specific part tho.
The Madbean glitchee has 4 across and its a little tight for my fingers with the lil davies. If it is something you plan to interact with a lot, you're probably heading in the right direction with the bigger enclosure.
