thunderaxe
hi all,
i've been playing around with the sour grape (keeley rotten apple) circuit, which is based on the op amp big muff ("dream fuzz"). so in comparing and contrasting the two, i noticed something interesting about the original op amp big muff -- the clipping stage op amp is biased by a voltage divider consisting of two deliberately mismatched resistors - 1M on the ground side and 820K on the V+ side, creating a slightly asymmetrical offset and, presumably, a slightly asymmetrical clipping as a result. looking at the equivalent voltage divider in the sour grape, it consists of two symmetrically matched 10K resistors.
so my first question is -- putting aside the asymmetry for now, is there any particular reason why the original uses 1M and the sour grape 10K? that's a difference of two orders of magnitude. secondly, if i wanted to play around with a bias pot on the sour grape, can i just replace either the ground or V+ side resistor with a 10K pot, or a 5K fixed resistor and 5K pot? or is there any reason why i should increase the resistance values on either side, say to 100K or 1M?
		 ) if you got rid of R7/R8 and replaced it with just one resistor from VREF, which is much cleaner than VCC. Something like this:
