Order Switch LED Off When Both Side Bypassed
The Grand Wazoo
Greetings, all. I built a dual pedal with a Mach 1 on one side and a Mahayana on the other. It has an order switch controlled by a 4PDT stomp switch. The order switch has a dual color LED that indicates which side is first.
As it stands now, the order switch LED is always on. I would like the switch to be off when both side are bypassed. I initially tried to tie this to the other footswitches SW pads but that just turned on all of the LED's because the grounds were all tied together when either one was turned on. Is there a way to achieve this?
