Solution: Using an audio probe and tracing the path of the signal, I found that the second op-amp stage was not actually sending out an amplified signal on its output, pin 7. I reflowed the solder on the parts in that stage and replaced the spec'ed IC, a CA3260, with a JRC4850D.
------------------------------ Original Post ---------------------------------------------------------
I decided to take another crack at the Oxide build. I bought a new board and repopulated it from scratch with the exception of one component (C13 a 100nF cap) which I tested and it came in right at 100nF after installation on the new board. Everything is to spec except C4 (I have a 47pF cap instead of a 51pF cap). Unlike last time I got a signal right away and all knobs were responsive. However, when I tested it in my signal chain it was noticeably quieter then the bypass level, even with the pedal's volume and drive knobs turned all the way up. I did some testing with the audio probe and the signal seems fine until there is a large drop in volume across R10 (a 47K resistor). I don't know if this is intended or not but the signal volume never recovers after this resistor. I checked the resistor value with my DMM and it came in right at 47K. I checked some other schematics for the Mostortion and they all have a 47K resistor in that spot of the circuit.
Any help is greatly appreciated.
