Yup
It will have a sudo log taper though
So, at 80% rotation, you'll have 44.4kohms
In the middle, you'll have 33.33k
First quarter will be 20k
You can under or oversize the resistor a little if you have an idea if you'll be closer to 50kohms or 0 to make it easier to dial in
Find a parallel resistor calculator if so
(Closer to 50k, go with 120, closer to 0, go 82ish)
