parentheses - fuzz/octave problem
stefanos
Hi all!
I'm building a parentheses fuzz. Problem is with the fuzz/octave part.
- Bypass signal works ok.
- Boost works ok.
- Q1/Q5 are ok (also all the other transistors)
- no sound in when the fuzz (or fuzz+octave) is pushed.
- for IC1with ground as reference I get
pin-1 9.1
pin-2 4.6
pin-3 4.13
pin-4 9.1
pin-5 9.1
pin-6 9.1
pin-7 4.6
pin-8 0
- when I select the led clipping and hit a chord, I can see the led reacting.
- is very silent when the fuzz (or fuzz+octave are) is enabled.
Any ideas?
Thanks!!
I'm attaching photos (front and back) in case they help..
Is there a way to check if the diodes are ok while mounted?
Thanks again!
