timc
I didn't follow the traces, but it seems like the Mini has the jumpered switch option in the Parenthesis build doc.
Leave it to me to mod something I've never built one of, ever . . . . .
o.0
Something did just occur to me. If you wire it up this way, what you're getting will actually be this:
Boost > Octave > Distortion
Since the Distortion and Octave are basically one circuit, activated by the same switch. From my tests running a boost before the whole pedal the Octave circuit gets pretty gnarly sounding if it has a really high-amplitude signal put into it. (Maybe not in a good way? Depends on your taste.) So another option would be something like this, if what you really want is Octave > Boost > Distortion:
Basically you'd find the Octave pot, and bend the middle (output) lug up, then solder a lead from that going to the switch used to control the boost. The other two legs of the pot would be soldered into the through holes as usual. Then when you install C5 (the capacitor right after the Octave Pot), just put the leg that's connected to R6 and R20 into the correct through hole. (You can use a DMM to see which of the through holes is connected to those.) The other leg, bend it upwards, and connect that to the output of the boost with an extra wire. Sorry this image is a bit blurry, wasn't sure how to include something from a PDF.
This is closer to what I did in my mod. I have no idea if it would work or not--I'm guessing you'll have the same type of self-oscillation that I did.
