cris_mas
Well, since i,ve got the Fractal Ax8 i've became aware of two things:
-i don't understand how people is so trapped in digital. I mean, is convenient and all, but it just doesn't sound like tubes. It just sounds "nice".
- The frequency response of the clean channel modeling is way more clearer in the digi world. I've started to play again with the Particle Accelerator (Bliss) but i've noticed how boomy is.
The first thing i thought was checking the filters in the circuit, the tonestack, and all seems to be the right values, except for this:
And most Fender guitar schematics are like this:
What happens if i swap those caps to those "fender" values? Will it change the frequency response in some way?
please forgive my ignorance, been a while since i don't analyze circuits this deep.
To wrap things up, i need (i think) the preamp to cut higher the frequencies, it's too much bass, to the point i have to crank all the way up the treble to equate to the response of fender amp models in the same settings. I know Fender are naturally "bass open" designs, but i've found that the PA is a bit too much, almost not usable ( this in headphones context, in live wasn't able to cut through mix ).
BTW i'm using a JJ ecc83s, i know they can be "warmer" than other tubes, but i've swaped with others and it was much the same.
Thanks in advance!
Thanks in advance!
