Need some help on this one. Built the pastel preamp but not getting any output signal. Went through and checked every resistor, swapped IC's, and reflowed solder on a few points that looked a little sus. , but still nothing. Have an audio probe and have good strong signal up to R31, but after that it starts to get pretty weak and distorted. I do have a weak distorted signal at pin 1 and 7 of the IC, but nothing at Q8 or Q9.
I did have to make some resistor values as I didn't have any 120 or 27 ohm resistors so that's why R15 and R29 look a bit off. I also found some 39ks that measured 38.4ish for R20 and R7. Any help would be much appreciated.
https://docs.pedalpcb.com/project/Pastel-PedalPCB.pdf
