I've noticed that when I import 125B drill templates from both PPCB and Aion into inkscape, the dimensions are not 62x177mm as per Tayda specs. They end up being 64.4x119.5mm (approx 2.5 mm larger in each direction). Is this extra size for the non-printable rounded edges of the enclosures? If so, should I resize the imported drill template or the document size in inkscape?
