rozencratz
I built a Paragon with some mods and the thing buzzes on bypass and it gets worse when a foot switch is on. I've confirmed all board components are correct, I replaced all off board components and wiring, I changed guitars, amps, speakers, and cables, but no matter what I do the thing still buzzes. I assume it's some grounding issue but for the life of me I can't find anything that would cause this.
When I used the pedal with another pedal before it that has buffered bypass, the buzz goes away, even just a tuner works. It still buzzes with a true bypass pedal before it.
I'm curious what would be causing this and if there is anything obvious i.ahould be checking or changing to mitigate the buzz.
Thanks all
Thanks all
