PedalPCB Precipice Overdrive build report
bluedmc777
Build Rating
5.00 star(s)
This was an easy build. However this was my second attempt because foolishly mounted the pots wrong on my first attempt. Live and learn!
I’ve only briefly played it to test it out but it’s a good sounding Marshall style pedal with a low parts count so I recommend it for new builders. It does have some good touch sensitivity and descent string separation. I didn’t have a TL082 on hand so I used a TL072. I’m curious if it sounds different with the TL082 so if anyone has tried both please let me know. Only issue i had was with the led bezel and led wanting to fit properly. I should’ve put the faceplate on last.
