Fama
Verified
I compared the 4 knob template (Son of Ben) to the Sandblaster build docs and it seems that they match up, except the LED hole is a switch, there's an another switch, and a led hole lower down. Compared the LED hole to the 6 Knob template LED hole and it seems to be a match, so I used the same coordinates. For the lower switch position, it seems to be placed identically compared to the lower two pots as the upper switch is compared to the upper two pots, so I used those calculations for the hole.
Maybe @Robert can chime in if my guesses (LED hole same as 6 knob and lower switch position) are correct, but it looks right to me based on the pdf.
