PedalPCB Tower Overdrive/Fullton Robin Trower 125b
OD is Glorious
Build Rating
5.00 star(s)
I think the pedal has a marvelous sound and the tone knob is useful. I think the pedal could use a touch more power - but just a touch. I did deviate from the build docs - used a 1N4007 in place of the 1N4005 that I do not have. Maybe with that change the pedal would be markedly different. I think it is a great OD with useable sounds. I would say the OD is very creamy sounding. The pedal worked on the PedalPCB platform but not the LED. Then I saw that the polarity was reversed. Very odd design, no a no k and I see a square pad and ... well you know the rest. So I swapped out that LED and boxed it.
I used a Tayda powder coated white enclosure and fitted it with a PedalPCB top jack plate. I used the Lumberg jacks and I copied the Fulltone graphic for the pedal top. 15mm red anodized knobs and a 5mm red LED. IMG_0029.jpeg IMG_0028.jpeg
