szukalski
Hey folks,
Building a pendulum and I am having an issue with massive gain on output.
All LEDs working, bypass working. I used an audioprobe to see that the signal is fine going into the LDR for the LPF, but going out it has massive gain. The LDR for the HPF doesn't have this issue.
I've swapped the LPF LDR twice, and the HPF LDR for good measure, but no change.
Looked at the voltage on the TL074, pin4 is 9v, pin8 is ~8v, the rest are what you'd expect, ~4.5v.
I used a C100K for the speed if that would have any difference..
Any thoughts?
Any thoughts?
