- Build Rating
- 3.00 star(s)
Even with the led's and ldr's like this the pedal is really loud. At first I had them facing each other directly. Maybe I have to paint the inside of the pedal black to reduce reflections?
It can get super fast so you might as well skip the rate led on the face unless you wanna cause some seizures. Make sure you don't put too bright of an led for the rate as well. I used pink without changing the CLR and immediately pulled that out. Been too lazy to swap the main power one since I couldn't seem to figure out led/ldr spacing anyway.
Also they have since changed tl074's since I built this awhile back so idk if that will become a problem in the future.
