Pepperbox / Volt Thrower - 18v -> 36v!
I built an Effects Layouts Pepperbox awhile back that I love. I just learned today that the Volt Thrower, of which Pepperbox is a clone, can take an 18v power input, and I am wondering if the Pepperbox can do the same. Seems likely, but I'm not certain and I don't wanna kill the thing. Help
If you used a 5817 and a ltc1144, and caps rated for the higher voltage, you can try.
Note, it is running at 18v. +9/-9 rails.
Note that +/-18v is the maximum rating for both the 1144 and LM308/OP07s.
So, you would be running the circuit at it's absolute maximum and the 5817 is a 20v diode so if your power supply spikes...
